USB transformer between two devices
DJ_AA
Joined Aug 6, 2021
502
Hi
I am to use a USB between a GSM module(Quectel BG95) and a microcontroller. The max speed will be 12 MB.
I have read that if you have EMC issues, then a transformer is needed, but it will reduce the speed.
Do we need to use a transformer between the module and microcontroller?
DJ_AA
Joined Aug 6, 2021
502
Sorry, my error. Yes a common mode choke.
Yes both are ends are on the same PCB.
There is a possibility, that the module might need a firmware update, whereby, i would need to force the microcontroller in RST, while the module using a USB cable is programmed. But this is just once.
