There are several peripherals connected on the I2C bus giving a total of 40pF capacitance, I am working with a maximum capacitance of 60pF, 10pF if my connection is external or 20pF if internal with an estimated wire length of 10cm. I am going to access an EEPROM while it isnt receiving power from its main unit. I need a real current source in order to allow the EEPROM voltage to go to 2.69V(0.81Vcc) in order to pass the (0.7Vcc) threshold to access the EEPROM. I dont really know how im going to connect the transistors on the bus lines....
