USB/Ethernet based High sampling DAC board
naumankalia
Joined Feb 19, 2016
49
Hi all
I am searching for some time a compact USB/Ethernet based Digital to Analog (DAC) board which can provide analog output with sampling update rate up to 2 Msamples/s (at least one channel). However, a bit surprisingly, i could not found any such board.
Is my requirement quite "unique" or i am not searching in right direction?
Thanks & Regards
Reloadron
Joined Jan 15, 2015
7,888
I will tell you what I suggest. Some time back I needed an D to A converter to handle generating 3 phases with a few special requirements. Since I was using National Instruments Labview I contacted a National Instruments Applications Engineer and it was likely one of my wiser moves. With your requirements you really want to contact an application engineer or two from some of the major manufacturers. You may get lucky in online forums but I suggest a good application engineer.
Ron
naumankalia
Joined Feb 19, 2016
49
Hi Ron
Thanks for help. I have used NI Cards but unfortunately NI solutions do not meet my requirement in this case. Do you have in mind some other reliable manufacturer for ADC/DAC boards?
naumankalia
Joined Feb 19, 2016
49
