USB device possible?
kubeek
Joined Sep 20, 2005
5,796
Well, I have seen a device which at first looks like a USB CDROM with a cd with drivers in it. After the installation it becomes a compound device with the rest of the functionality.
Off course you still have to install the drivers manually.
simo_x
Joined Dec 23, 2010
200
Off course it's possible.
You will need a microcontroller to install your own hardware driver, and this will communicate to the operating system.
Off course your OS should be able to recognize the driver.. This is done by using protocols & standards, which your driver should implement for communication.
GetDeviceInfo
Joined Jun 7, 2009
2,280
No. Windows has a finite path that it searches for drivers. If, as Kubeek mentioned, your device emulated a mass storage class, it could make available drivers for compounding, but windows would need prompting, or PC side scripting to direct it's driver search to that drive.
CDRIVE
Joined Jul 1, 2008
2,219
On vbforums.com similar questions pop up occasionally and are promptly discouraged because it violates a basic programming tenant.
"Thou shalt not make any changes to the user's operating system without their knowledge."
vss_vintorez
Joined May 23, 2011
3
Well I sill did not get one asnwer with good fundamentals !!!
50% say yes
and
50% say no
Think about mouses that work as keyboards
(they [use] the keyboard's driver)
(I want to [install/use] my own driver that would be in my own device)
CDRIVE
Joined Jul 1, 2008
2,219
50% say yes
and
50% say no
There are basically two families of USB devices. One family is recognized by Windows as 'HID' (Human Interface Device). HID's don't require drivers to be installed, as Windows recognizes what they are. Flash drives and USB printers fall into the HID family. Non HID's require drivers to be installed, because Windows has no clue of what they are.
vss_vintorez
Joined May 23, 2011
3
I need your best idead to complete this...
Tasks:
+ Execute some code or program in a computer.
+ Don't be detected by USB Flashdrive Blockers.
+ OS: Windows and AutoRun disabled.
+ Don't ask the user anything.
+ There is no roof price.
CDRIVE
Joined Jul 1, 2008
2,219
Tasks:
Not on your best day! Everything you're describing sounds sinister and violates basic principles. Besides that, you're in the wrong type of forum for this.
kubeek
Joined Sep 20, 2005
5,796
Tasks:
First you need to know what OS exactly is your target and what actualizations are present. Then you can try to find some unpatched vulnerability. Other than that it is impossible.
