USB data lines for battery charger
kahlenberg
Joined Oct 4, 2019
I want to design a LiPo/LiIon charger from USB port. I want to use BQ24074RGTR chip from TI, it is a battery charger chip.
But I can not find what I should do with D+ and D- lines.
All I found is charger circuits, not from battery side.
I need to know where/how I need to connect data lines at battery side.
If I don't connect datalines to anything, I think I can draw maximal 100mA from USB port.
What is necessary (D+, D-) to draw 500mA from USB port?
Thanks.
Papabravo
Joined Feb 24, 2006
22,111
Thanks.
You need to implement enough of the USB protocol to negotiate the higher current level. The USB 2.0 spec is a free download. Good luck reading and understanding what is required.
