someone can help me please : I'm looking for a device capable to intercept, save and forward command via usb cable between a computer and target device. is it possible technically to save the command and repeat the action from that device?
hi aliope,
Why cant you have direct access to the USB data stream.?
What is the purpose of the project, perhaps there are alternative ways of getting the data.
E
If you're OK with software running on the computer, check out BusTrace, see if they have a demo version so you can try it out. https://www.bustrace.com/bustrace10/index.htm The company I worked at in the past used it for sniffing SCSI/MMC commands sent to CD/DVD records over the USB bus.
