Thanks Tonyr,Like I mentioned before, I have a few ultrasonic humidifiers; however, I'm not prone to disassembling them to see how they work. In fact, I know I don't have a variable speed fan, I just have a variable opening to meter the amount of humidity that comes out. So I can only guess that the pot you have may be a wire wound type of pot. Capable of handling more current than the regular sort of carbon based pots which are very common. Unless they're using the pot to already control some sort of power supply to the fan, which is also entirely possible.
Can you take pictures of the guts? Since you're wanting to replace the mechanical dial with something controlled solely via electronic means, you should be able to open it and take a few pictures. If you can get some numbers off the actual pot - - - .
I'm thinking if it's electronically controlled then you might be able to replace the pot with a variable resistance IC, one designed for such work. However, I know they don't handle much current, so exactly how we proceed we need to know what we're working with first.
I traveled to our capital city and I'll be back home tomorrow. I'll dismantled the atomizer and give you the fine details. I'll also try to connect it's fan to PWM circuits and see whether it can work....
I'll also send some pictures as suggested....
All in all, I'm very much grateful for your responses and I'll make it a success...
