Hello people,
I was wondering, is it safe to connect a 650W UPS with a 2KV Inverter, would it have any side effects on the Inverter, its batteries or something else?
The reason why I am trying to create such a connection is, that my PC either restarts or freezes every time the power from the grid goes out and the inverter goes on backup (running on two 12 volt, 120 amp deep cycle batteries connected in series). The inverter works brilliantly, apart from the PC issue.
My PC is not a very heavy gaming rig, and I have a Cooler Master 460W power supply which comes with a 17ms holdup time. Seems like this hold time is not sufficient to accommodate the inverter switching to backup mode.
The answers I am searching for are:
1. is this set up safe:
2. Would the set up above have any side effects on the batteries? The darn things are bloody expensive!
3. Would the set up have any side effects on the UPS or the computer?
Apart from this, is there anything else I should be cautious about with the set up?
This is my first post on a forum, so I do apologize if my formatting or wording is not up to standards I would really appreciate your guidance and kindness in helping me establish a safe long lasting set up. Please do treat this matter as urgent.
Thank you, very much,
Cheers!
GRID-->INVERTER(2KV)-->UPS(650W)-->PC
Cheers!
