Up counter with 74LS192N and 74LS47 decoder
pentanol
Joined Dec 29, 2016
Hi
I am trying to make an up down counter using 74LS192N and 74LS47 decoder in Multism
This doesent work for the configuration I made. Where is the mistake in the attached picture.
spinnaker
Joined Oct 29, 2009
7,830
Are you going to define the problem you are seeing? Or do you expect people to look at every single possibility of what might be wron?
Reloadron
Joined Jan 15, 2015
7,975
You are showing a 50 Hz input frequency. Your display will likely appear as a blur. 50 Hz is .020 second which is sort of fast if you are expecting to see an incremental count on the display. Also your X1 through X4 reflect incandescent lamps which as mentioned, if that is the case the chip won't drive and again, at a 50 Hz rate you will never see them change on or off.
Ron
dl324
Joined Mar 30, 2015
18,490
Multisim won't simulate anywhere near 50 Hz. I've used a fast clock many times to get a reasonable actual frequency...
EM Fields
Joined Jun 8, 2016
578
Hi
This doesn't work for the configuration I made. Where is the mistake in the attached picture.
The incandescent lamps loading the counter will load its outputs to the point where the inputs to the 74LS47 will be out of bounds.
