up counter schematic equivalent to JK flip flop wont work.
mershi
Joined May 14, 2017
I am trying to build a counter using JK flip flop, and ideally I want to use only 7400, 7408 and 7404 ICs, and a button instead of clock.
what I Did first was simulate the whole thing in logism, used the jk-flipflop(block diagram), and it worked.
here is the schematic: http://i.imgur.com/4qEggqo.png
Right after that, i replaced all of the jk-flipflop(block diagram) with its schematic equivalent and it did not work.
here is the schematic: http://i.imgur.com/lLAcFvh.png
should i use different schematic for the jk flip flop?
35,210
What do you mean by "it did not work"?
You have to elaborate, i.e., tell us what it is doing.
Are you testing using LEDs? How are the LEDs connected to the circuit? Which LEDs are lit, which are not lit? Do the LEDs ever change state?
Did you debounce the push button?
dl324
Joined Mar 30, 2015
18,476
Welcome to AAC!
To minimize issues with broken links in the future, posting images on this site is preferred.
One flip flop:
The circuit looks correct. Did you try one flip flop to make sure it was working?
WBahn
Joined Mar 31, 2012
33,252
Circuits like this rely on the propagation delay around the feedback path being longer than the hold time. If the prop delays are zero (which is the case in many simulators by default) then they will not function.
