Unusual case with film capacitor from the power supply.
bob2
Joined Jun 15, 2019
226
Now with the LCR meter in use, you can check any components.
Before, I didn’t check such capacitors, I couldn’t even think that they can change their capacitance. Such a loss of capacitance is typical for electrolytic capacitors.
But when repairing a small power supply unit I discovered that the capacitance of the 470nF film capacitor decreased to 280nF.
Given the tolerance of 20%, this is much more.
Can this capacitor still be considered able to work, or should it be replaced?
What are the reasons for reducing the capacitance in such capacitors?
Wolframore
Joined Jan 21, 2019
2,619
metallized film capacitors generally lose capacitance due to loss of the conductive surface. Losses can happen due to over voltage, corrosion, self healing and partial discharge. They have a limited life. Whether you need to change this particular capacitor is how critical this value is and how it's being used. There are some situation where loss of half the capacitance will make little difference and others... where it is part of a RC circuit, where it may make a significant difference.
Danko
Joined Nov 22, 2017
2,247
Often it happens when germetization is damaged and moisture eats metallization on film surface.
EDIT: Too slow typing:(
AlbertHall
Joined Jun 4, 2014
12,660
If it's part of the snubber circuit, a low value will result in increased voltage and possible failure of the switching transistor/MOSFET.
bob2
Joined Jun 15, 2019
226
This is the capacitor of the input filter of the power supply unit. Apparently, the loss of capacity did not occur simultaneously, but gradually under the influence of voltage surges.
Do you think that having lost almost half of its capacity, will it effectively perform its function or does it need replacement?
It would also be interesting to know at what minimum capacitance is it still considered to be able to work?
narkeleptk
Joined Mar 11, 2019
599
Following your other thread where all testing was done in-circuit, I'm curious... Was this done in-circuit when you got this reading and if so, did you remove it from circuit and re-check it?
Wolframore
Joined Jan 21, 2019
2,619
That’s awfully small for input cap. Must be just for filtering high frequency. If you change it I would get one rated for higher voltage.
bob2
Joined Jun 15, 2019
226
I did all the measurements again.
The results are identical and do not depend on the test voltage 0.2.0.5.1V.
In-circuit measurements.
10kHz-250nF
100kHz-138nF
Removed from the board.
10kHz-250nF
100kHz-138nF
That is, in fact, the capacitor has lost about 70% of its capacitance.
With LCR Pro1 Plus, it became possible to check the parameters of such capacitors at different frequencies, despite the presence of other components.
In this particular case, there was no influence.
bob2
Joined Jun 15, 2019
226
Also very important secondary parameters are D and ESR for assessing the quality of a capacitor.
In this particular case, these parameters were much worse than the new one.
A multimeter in our case could not measure the capacitance of the capacitor, because it is shunted by an inductor.
Given the combination of the above factors, it is possible to check the filter capacitors for three parameters and make a decision about its further operation.
28,492
You identified the problem. Thank you.
But. Not indicated ways to test it. What thoughts do you have about this?
There are some ways to check the D and ESR qualitatively, which can tell if they are able to do what they need to do, but not what the actual values are. If the circuit is operating but either the dissipation factor or the ESR are excessive, the capacitor will feel warmer then the surroundings. So a calibrated feel with the fingers will tell if it is OK. But this is not an infallible test, it is just usually right. Measuring the AC component across the capacitor will tell a lot about the ESR, since the ESR is in series with the effective capacitance as well as the source impedance of the AC component of the voltage. Some capacitance meters also display the "D" factor, I do not recall the brand of the one that I used that did provide that reading. There are some quite simple published circuits for evaluating the ESR, often by the application of an AC voltage and measuring the current drawn, the better ones supply a constant AC current and measure the voltage developed.
narkeleptk
Joined Mar 11, 2019
599
@bob2, I get the feeling your a salesman or developer for this device, which is fine but I just can't believe that its the ultimate in-circuit testing device. As far as test equipment goes its not a big expense which makes it even more disbelieving that its accurate enough to take it seriously when testing in-circuit. I probably would get one to play with but I don't like tweezers that much and prefer probes so not sure it would be worth it just to have another lcr meter.
So far, from using this device can you give a few cons about it?
bob2
Joined Jun 15, 2019
226
Yes, but this has to do with electrolytic capacitors, not film capacitors. Or maybe you have such a circuit?
bob2
Joined Jun 15, 2019
226
some of those look like poly film... they can corrode and have various other issues...
Yes, in several situations, I became convinced that film capacitors could lose capacity for various reasons.
That's just recently, there was a situation with the film capacitor 1uF.
The capacitance is 558nF. That is, it has decreased by almost half. At the same time, the D of the capacitors with a reduced capacity and the new capacitor are almost the same. But the ESR differs significantly, several times.
Apparently the reason for this is due to the different processes that occur in the capacitor. Somewhere more prevails D, somewhere ESR.
