unregulated DC power supply using centre tapped full wave rectifier
dexterXD
Joined May 6, 2018
what will be the ripple voltage if ripple factor is 3% and output Voltage is 18Vdc in center tapped full wave rectifier?
Can you please tell me the formula?
WBahn
Joined Mar 31, 2012
33,282
Input Voltage though converted to dc output yet has 3% ac component
You are definitely on the right track. Ripple voltage has a pretty specific meaning and what you've described MIGHT mean that, but more reasonably could mean a couple of other things.
So I'd suggest doing a bit of searching on ripple voltage and see if you can't refine that a bit.
