I have a couple of LT1632 in SO-8 package and they don't have a notch or any obvious mark to denote which end has pins 1 & 8. Would you assume the left side of this picture is pins 1 & 8?
I soldered it to a DIP breakout board and connected the right-side amp (pins 5-7) as an inverting amplifier but saw only noise. I tried turning it around in case I was wrong but had no luck. When I turned it around again (back to the original orientation), I started getting a clean output signal but at unity gain when the gain should have been 3.7. Both amplifiers behave the same.
I suppose I could have damaged it since one of the two ways I oriented it must have been wrong. I have another but I don't want to risk damaging it too not knowing how it should be oriented, otherwise that's $13+ down the drain. These things are pricey!
And all this because I accidentally got the SO-8 version when I meant to get the DIP version.
