Does anyone know what this diode/rectifier symbol is? This diode/rectifier is on a small motor control board used in a horizontal milling machine. I am repairing it for a friend of mine and wanted to make a schematic. The diode checks like a standard diode, so it is probably good.
The milling machine is probably late 1950's or early 1960's. It contains a other "antique" electronics parts like a "non polarized Klep-Sel selenium diode" (which I have identified from an old International Rectifier spec sheet) (roughly equivalent to a modern MOV) and it contains a 20A stud mount SCR (which I have also identified) and it contains an (old school) glass encapsulated bimetal protector (resettable breaker).
I have been working on electronics for 50 years and have never seen this diode/rectifier symbol used, so I would like to identify it. The diode is similar to the old "top hat" diodes used in the early 1960's. A Google image search does not turn up anything like this.
