Unknown diode. Need help
jijo55
Joined Feb 18, 2020
Hello everyone,
Currently I am trying to repair my air conditioner's DC motor.
the aircon is 12LGC and the motor model is MFE-40 VVL.
but this is not important.
I have opened the DC motor and looked on the PCB inside. There is 2 ICs and several resistors, capacitors and... one diode.
Outside the diode looks good, there is no physical damage, but has over 4MOhm resistance in both directions -> it should be replaced.
The diode is marked only as "20" and I cannot find what is it.
Is it a zener or shottky?
I have made a picture of it and attached the scheme. May be someone familiar with electronics can guess and suggests what kind diode I should use.
wayneh
Joined Sep 9, 2010
18,167
My guess, and that's all it is, is a 20V zener to suppress transient spikes on that 15V line.
The bad news of that, if true, is that the diode doesn't normally do anything. A failure would not cause symptoms. But it might indicate that a serious transient occurred and may have damaged other things.
Alec_t
Joined Sep 17, 2013
15,156
If the 'diode' is in fact a bidirectional TVS device, you would expect a very high resistance in both directions if the device is ok.
jijo55
Joined Feb 18, 2020
@wayneh
Thank you for your reply.
Yes, the IC behind (SMA6822) is also damaged. The resistance between vcc and vb1, vb2, vb3 is different which is a sign, that it should be replaced.
@Alec_t
Good suggestion! May be it could be such thing. The "diode" has no cathode marking.
jijo55
Joined Feb 18, 2020
Reversed the diode. Here are the readings:
20.2 / 20.07 / 0.025mA
21.04 / 20.03 / 0.16mA
22 / 20.01 / 0.3mA
I think the diode is OK, and I'm gonna re-solder it.
Thank you! :)
Alec_t
Joined Sep 17, 2013
15,156
From those and the previous results it looks like a diode with a reverse breakdown voltage around 21V. So I agree with Wayneh that it's probably a (nominally) 20V zener or Scottky diode.
