I need some help in wiring this chip.
My needs are extremely simple ( compared to what this chip can offer)
You need to look at the datasheet attached.
All I want to do is set LED on when input voltage 1 is higher than input voltage 2.
There are examples in the document to do just that, but I am not able to do it I set one input to 5v and sourced input 2 from a variable power supply.
The circuit was powered by another variable power supply. We are talking here of voltages in the range of up to 15 volts.
Once I get this going then I will be able to investigate the more complex functions this chip can do.
Here, I am repeating myself again for the sake of clarity. I want to use this IC to compare two voltages, and activate a LED when one is higher than the other.
