uninstall ask.com & other ads
aamirali
Joined Feb 2, 2012
412
In browser, I get install these freaking adware/ask.com & other.
Even I remove them completely from browser or any other they keep on showing again.
How to remove them permanently.
1. Will malwarebyte be able to remove them or not
sirch2
Joined Jan 21, 2013
1,074
Google it, there is some good advice out there and next time you install something read very carefully what is on the installation dialogs, uncheck the options for anything except the thing you intend to install.
tom_s
Joined Jun 27, 2014
288
add/remove programs - ask.com will be there if its installed.
IE aslo has a feature of totally resetting the browser to default (original) settings.
JDT
Joined Feb 12, 2009
657
Also, if you download something, check very carefully where its coming from. For example: if you want flash player, the URL should have "adobe.com" right at the start.
studiot
Joined Nov 9, 2007
4,998
I'm sorry to tell you that Malwarebytes may not remove Ask successfully.
Successful removal depends upon the depth of infection.
It may simply be that you have not changed your homepage away from Ask (MB does not do this) and the browser goes there and reinfects as soon as you open it.
Change this offline before using the browser online.
Sometimes Ask is protected by another program. 'SearchProtect' is one such. Some are hidden.
Join up to either
http://www.majorgeeks.com/
or
http://www.bleepingcomputer.com/
and let them help you.
22,111
I recommend the Revo Uninstaller. I kept getting a 1316 Error because it could not locate the original uninstaller in C:\Windows\Installer\...
electronis whiz Technical Repair 2
Similar threads
CA AV uninstall problem
