Unexpected voltage drop with MOSFET model in LTSPICE
m121212
Joined Jul 24, 2011
102
In attached circuit I expect the FET to be biased fully on, with RDSON = 6 ohms. Current through the loop is 10V/(100 + 6 ohms) = 94mA.
Drop across M1 should be 566mV.
Drop across R1 should be 9.43V.
V1 Rser = 0, so no drop there. I tried several other FET models but I am seeing similar strangeness, so I wonder if my sim config settings are wrong.
ericgibbs
Joined Jan 29, 2010
21,651
hi m12,
Have you considered the effect of the voltage drop across R1, that decreases the Vg to Vs voltage,
E
No.
The MOSFET is connected as a source-source follower, so the drop will be at least the Vgs(th) value.
Right!! The thing about a source follower such as this; Vout is more variable between FETs then it would be with a BJT in emitter follower configuration. This because the Vgs threshold voltage usually has a range of 2-3 volts.
MOD NOTE: Fixed quote tags.
