Unexpected output in my circuit
Bamerni
Joined Jun 26, 2016
53
Hello everyone again
My problem simply is that I connect a zero gain buffer between two circuits (low-pass filter and subtractor)
But what Wonder me, that there is a voltage drop in the buffer stage of about 1.5 volt
Can anyone explain to me why this happened?
Is the solution to overcome this problem is to connect a buffer stage with gain?
Thank you in advance
ScottWang
Joined Aug 23, 2012
7,509
Please check the output side as attached circuit, the output voltage as:
Vout = Vcc - (Vbe1_Q11+Vbe2_Q12) - Vce_Q11 - V_Ro (V_Ro is the voltage cross on the output resistor)
= 5V - (1.3~1.4V) - (0.1V~0.2V)- V_Ro
LM358 datasheet -- Please check the datasheet on page 12 and to see the output side.
