Understanding this self-power power supply design
Xavier Pacheco Paulino
Joined Oct 21, 2015
728
See below a self-power supply design I took from a App Note from Texas Instruments.
My question is about the voltages at the inputs of the comparator U6A. At the inverting input, the reference is set to 0.7 V because of the diode D12, right? At the non-inverting input, the voltage is defined by the resistor R41//R42. If the voltage across C27 increases, the voltage drop across R41//R42 will increase so triggering the comparator. Am I right? In addition, what's the purpose of C34 in parallel with R43 at the comparator's output?
Dodgydave
Joined Jun 22, 2012
11,395
The Voltage across the supply will have to be over 39.7V to trigger the Zener on pin 3 of the U6a, the capacitor C34 is to assist fast turn off for the fet.
