Understanding Mosfet Circuit with PWM to control voltage 0-10v
Status
Not open for further replies.
Link068
Joined Apr 10, 2017
31
I am wanting to control a voltage range of 0-10v across a 10k load with PWM from a micro. Now I was told to use this circuit with an n channel mosfet:
This is what I understand so far: R1 is to reduce current flowing into the base R2 is used to pull mosfet closed when its not conducting
I was wondering if I could have help understanding what R3 is doing?
Any help would be great.
Cheers
Daniel Sala
Joined May 28, 2015
65
(That's a single transistor inverter - high input is low output/sinking, low input is high output.) R3 is a pull-up to Vsupply, it's also limiting the current going through the NMOS when it is on. It's a voltage divider, so consideration must be made about the value R3 is given, e.g. 10k + 10k load = 5V when the NMOS is off, 1k + 10k load = 9V at junction of R3 and Rload.
Alec_t
Joined Sep 17, 2013
15,156
Since this is Homework, a couple of suggestions which are a bit picky but might score you more marks:
1) Get into the habit of giving all components a designator, so that discussing the circuit is easier. So, let's call the 10k resistor R4 or Rload.
2) MOSFET transistors have a gate, not a base. The transistor shown is N-channel, not NPN.
Mukesh8169
Joined Mar 24, 2023
What is input voltage. No Velu showing R-1,R-2 & R-3 i need output 0 to 10 volt veritable so please send complete circuit diagram.
Irving
Joined Jan 30, 2016
5,195
To get a 10v output with that circuit you need a greater than 10v supply because of the voltage-divider formed by R3 and the 10k load. It's also inefficient and wastes energy at lower output voltages through heating of R3.
Whoever advised you to do it this way is ill-informed.
The correct way to do this, for a ground-referenced load, is with a P-channel MOSFET.
Ian0
Joined Aug 7, 2020
13,286
Do you want a linear analogue voltage variable from 0-10V range across the load, or do you want a PWM signal that is 10V peak?
Status
