Understanding Feedback Using a dsPIC MCU
GettinBetter
Joined Jun 22, 2018
41
So I've looked at various feedback block diagrams and been mulling it over in my head for some time now, and was thinking about how to drive a stepper to a particular point.
My Sensor gives me a data that I've decided (by some unknown as yet, method) means rotate the shaft 10 degrees, which translates to x steps (multiplied up if microstepping).
Would I then just create a pulse by toggling the pin x times, read the encoder and adjust if necessary? or is there some really clever way of doing it (i.e. PWM). As I only need to move the shaft +/- 45 degrees, it's only 200 at 8 microsteps (1.8 degs /step). I also need minimum latency in the system, so the method I finally adopt is quite crucial.
What are your thoughts peeps.
Regards
GB
