Sorry for the late reply. It’s a college project.hi 0306,
Is this a College assignment project or Homework.?
E
E
But that assumes that the transmitter is mounted on the 'target'! The OP says "When the device detects a person, it will turn it on." So everyone would have to wear an ultrasonic transmitter!A single ultrasonic transmitter ‘pings’ the receivers. Each one will return a different distance which is then used to triangulate the position.
dj
No, no devices are mounted on the target.But that assumes that the transmitter is mounted on the 'target'! The OP says "When the device detects a person, it will turn it on." So everyone would have to wear an ultrasonic transmitter!
Sorry - I'm not trying to be facetious, but I think this is outside the original requirement.
I am inclined to agree that a PIR sensor is far more suitable for this apllication.
So, this sensor has both the transmitter and receiver. Three of them will allow you to determine the exact location of a person or object. Two have their transmitters removed, so the echo from transmitter on the third activates all three receivers. Calculating the distance from all three receivers allows accurate triangulation of the object /person reflecting the signal. Note (this is critical), nothing is located on the person/ object!But that assumes that the transmitter is mounted on the 'target'! The OP says "When the device detects a person, it will turn it on." So everyone would have to wear an ultrasonic transmitter!
