Ultrasonic amplifier/filter problem
mskh744
Joined Dec 2, 2013
2
I'm designing an ultrasonic receiver circuit that should deal with a 10 mv signal( may be less !! the limitation here is due to the transducer itself http://www.ram-e-shop.com/ds/general/Ultra_Soinc.pdf ).
The signal is 40 Khz sinusoidal pulse-modulated signal (pulse duration=1.8 s; pulse width=83 ms) , and I used LM358 for multistage amplification, but I ended up after 4 stages of inverting amplifier configuration (each stage's gain is supposed to be 100; meaning R2/R1=100) with a 1 volt p-p signal and a 0.75v p-p noise !!
I need to get a 0-5 volt signal when I receive the 83 ms pulse, but I'm starting to think its not possible using commercial amplifiers.
Any suggestions on the opamp selection itself??
I also tried to use multistage BJT amplifier (CE configuration) and the signal to noise ratio was much better than the opamps, but the gain was not sufficient!
I tried to use a band pass filter at 40 khz to eliminate the noise, but no active filter using lm358 could be precise and a passive RC or RLC filter would kill the mv signal I want.
I used Multisim simulator before I implemented the circuit and it showed some satisfying results. However, when I use the discrete components (whose reliability is not guaranteed) and measure the results on an oscilloscope, its rather depressing results.
Any help with the amplifier or filter circuit would be much appreciated.
sirch2
Joined Jan 21, 2013
1,079
Here's an ultrasonic circuit I adapted from others on the Web. It works differently to what you propose, there are two stages of amplification which then dives a schmitt trigger to get 0 or 5v on the output.
LvW
Joined Jun 13, 2013
2,066
What does this mean (...could be precise..)?
Of course, you can design a bandpass filter around 40 kHz.
Question: Are you required to use LM358?
In this case, indeed a pole frequency of 40 kHz is rather problematic.
However, this should be possible using an opamp with a larger gain-bandwidth-product.
Dodgydave
Joined Jun 22, 2012
11,395
Can you post your circuit, also when you receive this pulse do you need an exact replica of it or just a 5v output signal to represent it?
ScottWang
Joined Aug 23, 2012
7,509
Hi Dave.
Which one you are replying to, the TS or the new thread?
If for this thread then it will be stand here, otherwise I will be move it to the new thread.
