uc3843 COMP pin
myil
Joined May 2, 2020
148
Hi Everyone,
I would like to design a flyback converter with uc3843. But I quite don't understand what the COMP pin is used for and how to set it correctly. I am totally new on power electronics. Can anybody explain in a dummy way so I can learn it.
Best regards
myil
Joined May 2, 2020
148
hi my,
Why have you deleted the question while I was typing a response.?
Read page #9 of the PDF it explains the Compensation pin #1
E
Hi Eric,
Sorry my question was shortly : why do we need another compensation network for comp pin while we already design for the feedback loop? Additionally, how can the resistor and capacitor value be calculated ?
Thanks for your reply.
Papabravo
Joined Feb 24, 2006
22,116
The purpose of the compensation pin is to modify the shape of the closed loop response to improve stability. In a typical case it accomplishes this by introducing phase lead. Calculating the component values requires knowledge of the closed loop response without the compensation.
