UART viewing on Android and iPad devices
DJ_AA
Joined Aug 6, 2021
502
Hi
My PCB output a log on the UART ports.
At times, I need to debug the device out in the field and taking a laptop is something I prefer not to do.
Is there any device, which I can connect onto my Phone or IPAD, which then I can connect a USB UART port so I can view the UART logs on handheld device?
Jon Chandler
Joined Jun 12, 2008
1,648
If your Android phone has USB OTG (On The Go), you can get an adapter cable with a USB Micro-B or USB C connector (as appropriate for the phone) to a USB A connector. (These are specifically called USB OTG cables.) Then you can connect many different USB devices; in this case a USB – UART Adapter. Then get a terminal emulator from the Google Play Store and you're all set.
DJ_AA
Joined Aug 6, 2021
502
Sorry, i found an app that verifies if the device is compatible. My device is compatible. .
Is there any recommended UART terminal emulator?
Jon Chandler
Joined Jun 12, 2008
1,648
This is one I have used. The USB–UART chip used may make some difference in how well a particular app works.
I vaguely recall having to download a driver for the CH340 chip I like to use, but the details are lost in the fog
