I did itGood response!
Based on my test using the simulator, the code should work if the PIC is running.
Try the sim test in #18? If that works, the problem is likely hardware or your UART setup. Have you tried the terminal test procedure outlined in #14 I.e are you sure the terminal works?
elcome show in uart1 output window
In simulator you set 5mz but I have 20 MHz crystal on the board
I think something wrong with Uart setup
