UART level convertors and Baud rates
DJ_AA
Joined Aug 6, 2021
502
Hi All
My microcontrollers works on 3.3V but I have GSM module that has pins that are using 1.8V.
I am currently using a transistor level convertor as shown.
What is the maximum baud rate that can be achieved?
If I need a much higher data transfer is there more suitable IC?
DJ_AA
Joined Aug 6, 2021
502
Great, it seems that there is many in stock as well.
Well , the issue is I am trying to get the ESP32 and B95(which will be upgrade to EG-9X) talking. The aim to use EG-9x in the future which has much higher data rate, as I need to send large audio files.. ESP32 does not have native USB port, therefore i need to use high speed UART instead.
If I am correct ESP32 can work up to 2mb before errors?
