UART data transmission
King2
Joined Jul 17, 2022
163
I have a question regarding UART. Could someone please provide more details on what it means by asynchronous in UART especially in terms of data transmission
Papabravo
Joined Feb 24, 2006
22,111
There are some fine semantic distinctions here. A character frame consists of 10 or 11 bits. Each of those bits takes the same amount of time. Over such a short run of bits it is possible to accurately decode the actual meaning even if the clocks in the transmitter and receiver are running at slightly different rates. Between character frames there can be an arbitrary amount of time with no activity. In short it would be more correct to say that serial transmission via UART is bit synchronous, but byte asynchronous. It is also true that UART communications does not require a separate clock.
It should be noted that there are protocols where entire frames with thousands of characters are bot bit and byte synchronous and require the availability of the transmitters' clock signal.
