Two stage BJT amplifier with feedback
The Electrician
Joined Oct 9, 2007
2,986
The pspice shows the oscillations already for RFb=2344.06792623
Why should there be any oscillations? If RFB is > 1673.424 ohms, then the negative feedback is greater than the positive feedback.
I don't see any oscillations in spice and tnk didn't mention any occurring if RFB is greater than 1673.424+ ohms.
Make sure the transistor beta is set to the correct value in your simulation.
steveb
Joined Jul 3, 2008
2,436
... I hope we'll hear from hgmjr and steveb.
Sorry I haven't chimed in on this one. I've been busy lately, but I'm watching this thread with interest and would like to see your solution with the generalized admittance matrix.
Just to contribute something without spending too much time, I thought I would mention the method of inspection for the input impedance calculation. It is not too difficult to write the input impedance formula just by looking and noting the effective reflected impedances caused by the current gains.
By inspection I get the following input impedance formula, where the // symbol means parallel combination.
\( R_i_n=R_1//R_2//\Biggl(\biggl(h_f_e_1+1\biggr)\biggl(r_e_1+r_e_1_1// \bigl(R_f_b+r_e_1_2// (r_e_2+{{R_3//R_4//R_c_1}\over{h_f_e_2+1}})\bigr)\biggr)\Biggr)\)
For the first circuit with infinite feedback resistor, I get Rin=11272 ohms and for the second circuit with 2344 ohm feedback resistor, i get Rin=11180 ohms.
Hopefully, I didn't make a mistake.
The Electrician
Joined Oct 9, 2007
2,986
Apparently a mistake has crept in there somewhere, because with the feedback resistor, the input impedance is 5506.429Ω. :-(
t_n_k
Joined Mar 6, 2009
5,455
With Rfb = 5000 plugged into my EXCEL spreadsheet version ....
I get Gain= 6.9244614202E+02
And using goal seek in the spreadsheet I get Rfb = 1.6734242404E+03
to achieve a gain of 1E+12 (not infinity but getting there!). Actually Goal Seek falls over with a target >> 1E+12 ....
Haven't even thought about the black box challenge.
The Electrician
Joined Oct 9, 2007
2,986
Some small error must have crept in; the gain should be 689.001136. Jony130 went back and edited post #17 and got the results for the RFB = 5000Ω case.
Are you using the nodal method? In post #15 you got the original gain as about 1645, which is pretty close to the exact value of 1646.5301225. You were going to recheck that value. What do you get for it now? Are you still a little off? Maybe a small error in your spreadsheet.
That's correct.
t_n_k
Joined Mar 6, 2009
5,455
With Rfb=5000, I get Rin = 9.307408213914E+03
That's it for me - thanks for the challenge Electrician, but it's worn me out!
The Electrician
Joined Oct 9, 2007
2,986
For RFB=5K
If I don't make any mistake in calculation here are the result:
V1=0.578180V---> node 2 in your diagram
V2=-46.318011V--->it is a Ku= node_3/node_1 in your diagram
V3=-38.341042V--->Ku=node_4/node_1 in your diagram
and
Ku=node_5/node_1|=((V2-V3)/R7) *β2 *R6=689.000225[V/V]
Rin=R2/(1-V1)=18481.5798Ω ---> not take into account R1,R2 in your schematics.
And gosh I need a spreadsheet. [/URL]
All correct except for some numeric errors beginning to creep into your results around the 6th decimal place.
Referring back to your post #13, I said:
You have in effect analyzed a circuit that has an AC ground connected to node 2 and and with RFB connected from node 4 to ground, rather than between nodes 2 and 4. Such a circuit has exactly the same gains from node 1 to all the other nodes.
Now, to extend the problem, imagine this. Build each circuit, my original one and the one you analyzed and enclose each one in a black box. Each circuit's reference node (ground) is connected to the metal of the box. The other 5 nodes are connected to terminals on the outside of the box. Since both circuits have exactly the same gains from node 1 to the other nodes, how can we tell them apart?
Do you have any ideas on this one?
t_n_k
Joined Mar 6, 2009
5,455
Thanks Electrician - I found the error in my spreadsheet and it all now agrees with the values you and Jony130 have found for the various values of Rfb.
steveb
Joined Jul 3, 2008
2,436
Interesting! It seems that the feedback modifies the effective current gains, which makes it more difficult to see the input impedance by inspection. This proves your initial point ....
I want to show how just the addition of a single feedback resistor, RFB, between the two emitters substantially increases the difficulty of analysis.
I'll look at it some more to see if a more "intelligent" inspection can yield the correct answer, or if a full calculation is necessary.
EDIT: I don't see an easy way to get the input impedance by inspection. The effective current gain in each stage seems highly dependent on the interaction between stages. At this point I would just use "brute force" and write out the equations, which might take me about an hour to do without mistakes. However, I just don't have the time now. I'm curious to see how the admittance matrix approach simplifies the calculation.
steveb
Joined Jul 3, 2008
2,436
Ah, this is interesting. I just noticed that this input impedance is what you expect if the emitter resistor of stage 1 was completely bypassed. So basically, your feedback resistor is negating the effect of the unbypassed portion of the emitter resistor on stage 1. For the AC signal, the emitter of the stage 1 transistor acts like a virtual ground. Correct?
The Electrician
Joined Oct 9, 2007
2,986
Yes, I chose the value of RFB to get just that effect. Jony130 noticed it in post #13.
Jony130
Joined Feb 17, 2009
5,600
But, which circuit have the same gains ?
For sure not those in the first post.
And pspice show oscillation for RFB=2.5K, CFB=100uF and β1=300; β2=200.
And for RFB>3K oscillations disappear
The Electrician
Joined Oct 9, 2007
2,986
For sure not those in the first post. [/URL]
When I said in post #18:
I was referring to your analysis in post #13, and the second of my original circuits, the one with RFB present.
The Electrician
Joined Oct 9, 2007
2,986
That's very interesting. If I make RFB 2500, I get very low frequency oscillations after a second or so.
If I make C6 = 10uF, the oscillations don't start.
If I make C1 = 1uF (and restore C6 to 100uF), the oscillations don't start.
A full analysis of the circuit, including the effect of all the capacitors (which we haven't included so far in this thread), should show why this happens.
