two solenoids in parallel
Deleted member 115935
Joined Dec 31, 1969
If current consumption is a concern,
there are options
Solenoids tend to need a big current spike to get them moving , but much lower current to hold them,
Many solution to this if you want to go down that route , such as PWM or capacitive discharge
but all more complex than you have.
If simple works, stay with it,
Eric Taylor
Joined Jul 1, 2017
thank you all!
here is the circuit I finally did.
Power Source: 12 Volt and 3 Amp.
1 Transistor - TIP 120 Darlington
Ic = 2 Amp (2 parallel solenoids each drawing 1 Amp)
Diodes with each solenoid - 1N004, 1 Amp.
Ib = 10 Amp (beta =250)
R= 340 Ohms.
Arduino Pin 12 = 5 V
I was able to make both solenoids work and no heat.
The Transistor however was getting hot..although not a lot. what is the power on Transistor? 12V X 2Amp?
Also, on the behavior of diodes, since each diode is 1 Amp, is the 2 Amp current dividing between diodes in the parallel circuit?
thanks. Still learning so please bear with me.
Eric.
dl324
Joined Mar 30, 2015
18,436
Vce * I, or about 2W.
One diode will have a lower forward voltage than the other; that one will take most of the current. Since the diodes can handle a surge of 30A, one is sufficient.
