Two PSU`s from one toroidal
daryll
Joined Jan 22, 2021
6
Is it possible to take the secondary's (15-0 15-0) from a toroidal and split the output to two power supply's 15-0-15 and a 12-0-12 using a wago block to split the supply.
power supply.jpgSorry about the pic , done in haste...lol , the wago block has 2 terminals per contact , so the two 0 v will join in the block.
Wago block.
One 15V goes to the first terminal, each 0v goes to the second terminal , the other 15v goes to the last terminal , the other side allows two wires from each terminal for outputs
Cheers
Daryll
wayneh
Joined Sep 9, 2010
18,130
Yes, but load variations on one side might impact the other. That may or may not be a problem - depends what you're doing.
daryll
Joined Jan 22, 2021
6
I think (yes , I do that sometimes) both supply's will be drawing about 250ma per rail , thats for each supply , so +15 at 250ma , -15 at 250ma , +12 at 250ma and -12 at 250ma
MaxHeadRoom
Joined Jul 18, 2013
30,756
If identical winding's, they are usually wound bi-filar so you can use them in series, parallel or separately, the advantage with a toroidal is it is easy to add an over-wind secondary if needed.
Max.
