Two mixer in one RF IC
FabulouSS
Joined Feb 5, 2019
10
Hello, world! :)
Are there analogs of the NJM2552 chip, but with two mixers (IF1 - ~ 10.7MHz, IF2 - 455MHz)?
Thank you for your attention and apologize for the poor knowledge of English (I use Google translator)
BR-549
Joined Sep 22, 2013
4,928
It will depend on what exactly you are doing. There are chips that have 2 IFs......but it matters what you are doing.
Edit: Try searching for "am fm ic chips", and see what you get.
FabulouSS
Joined Feb 5, 2019
10
I forgot to add - I work only with amplitude-modulated signals.
I make ANALOG (NOT DIGITAL) receiver in the range of 24-29 MHz. The desired selectivity in the image channel is achieved only with the help of two frequency conversions. For example, I receive a 25 MHz signal, the first IF is 10.7 MHz, and then the conversion to the second IF is done - 455 kHz.
I could not find the desired chip on the Mouser/Analog Devices and some others sites. :(
Externet
Joined Nov 29, 2005
2,681
Look at the data sheet for TA2003. Currently am into detecting AM from VHF. Seems the sections of that chip can be independently accessed.
Samantha Groves Analog & Mixed-Signal Design 17
Z Analog & Mixed-Signal Design 11
Similar threads
RF mixer IC
Audio mixer. ..#2
