Two level Nor gate implementation
Tom Nelson
Joined Oct 27, 2015
I am supposed to simplify the following function and implement a two level nor gate circuit:
f(w,x,y,z) = wx'+y'z'+w'yz'
I made a k-map, and the POS form as follows: (w+z')*(x'+z')
A little confused on how to implement in terms of nor now? How do I make the nor gates function as two or gates and an and? Just invert everything?
dl324
Joined Mar 30, 2015
18,491
Welcome to AAC!
Please post your work.
It would be easier to read your post if you used all caps for the gates:
This is easier to read:
How do I make the NOR gates function as two OR gates and an AND?
Papabravo
Joined Feb 24, 2006
22,115
If you think of what a NOR gate and it's DeMorgan equivalent do in terms of signal levels it may become clear to you. The following two statement implement the exact same logic function:
  1. A HIGH OR a HIGH is a LOW (Basic Definition of a NOR function)
  2. A LOW AND a LOW is a HIGH (DeMorgan equivalent of a NOR gate)
Does that help?
WBahn
Joined Mar 31, 2012
33,324
The key is to apply DeMorgan's Theorem.
It is probably easiest to do graphically (what I call "bubble logic"), but can be done with Boolean Algebra as well.
For instance, if you have A*B and apply DeMorgan's, you have (A' + B')'
You should be able to recognize this as A' NOR B'. If A and B are the OR of two terms, what do you have?
