I have elevator access control, that using one Channel Relay as contactor,
when i use the relay only for one button panel its working normaly, but when i try to combine with another button panel on a single Relay
the button starts to misbehave such as when i press one button the other button is responding,
my guess its because voltage different on each panel button.
i try to find the solution first before buying separate access control for each button panel, because lift access control is expensive
i attach simple schematics, how do i solve this?
