Hi there,
I'm trying to make a circuit using two 555 timers set at two different frequencies. However I've set the two timers at different frequencies and the seem to conflict with each other. For example unless both are set at the same frequencies they work fine. If i alter one value of the capacitor for example then it'll effect the frequency for the other timer!
Is it even possible to use the same supply for somthing like this?
Many thanks
Many thanks
