I am using CAT6 wire to pass 0-3.3v data and a small amount of power.
The wire has 4 twisted pairs.
I want to pass 4 signals and +5VDC.
I plan to pair the following:
signal1 with ground
signal2 with ground
signal3 with ground
signal4 with +5vdc.
The power supply has large capacity. (low internal resistance, lots of capacitance and no ripple.)
signal4 is 0-3.3v at 1000Hz square wave over ~2meters.
Is it bad practice to share a twisted pair with a signal and +V?
If so, why?
I am developing a PCB and I plan to add footprints on each end to couple the +v to ground with an extra capacitor if needed.
signal1 with ground
signal2 with ground
signal3 with ground
signal4 with +5vdc.
If so, why?
