So, The lights works, but I think I might be connecting too many LED's to the one PIC. I know it can handle them at the moment but its a lot of current to be sinking. If I light up 6 LED's at once, minimum 20mA each, Im already up to, and probably over, 120mA, which doesn't seem sensible considering im connecting a bunch of other circuits to the PIC.
What happens if you overload the PIC. Max sink current is 200mA. Does it get hot?? Or pop, or just stop working?
And , is there a better way to connect LED's? I dont want a lot of peripheral circuitry? Analogue electronics is not my strong point, and I dont have any easy way of making good circuit boards. So whats the best way to power that many LED's.
I suppose I could use somehting as simple as AND gates, if the can sink enough current. At least that would isolate the LED's from the PIC. But surely there is a better approach. Maybe an IC designed just for this purpose? I would have though there would be something but I just keep finding 7 segment LED displays. All I want is an IC that will except 16 inputs with direct control over 16 outputs, and will handle higher currents than my PIC. Could anyone suggest something??? Thanks?
