Turn on and turn off timing in Mosfet
Kusagi
Joined Jul 9, 2021
How CGSO and CGDO affect to turn on and turn off timing in Mosfet?
and how can i get CGSO and CGDO value from datasheet?
Ian0
Joined Aug 7, 2020
13,230
Cgso has to be charged by the gate driver.
Cgdo suffers from the Miller effect, so appears as though it is larger than it is by a factor equal to the voltage gain of the stage.
As the voltage gain of a power MOSFET stage is not so easy to quantify, it is often easier to think in terms of gate Charge instead of gate Capacitance. Switching times are approximately equal to gate charge divided by gate current.
But, as @LowQCab says, let SPICE do the work!
Kusagi
Joined Jul 9, 2021
They need to be "Modeled" in a Computer Program to display their interactions.
Thank you for your reply.
That means we can't calculate CGDO and CGSO parameters.
But I see in the picture which you attached above have equation:
Ciss = CGS + CGD
Crss = CGD
Coss = CDS + CGD
So could I calculate CGS0= Ciss-Crss , and CGDO = Crss ?
LowQCab
Joined Nov 6, 2012
5,101
I have never seen the terms CGD and CGS with an "O" added to the end,
What does the "O" represent ?
"" So could I calculate CGS0= Ciss-Crss...... ""
CGS, CDG, and CDS are Specific-Measurements.
Ciss, Crss, and Coss, are "Derived-Values".
Study the picture provided, most of the important formulas are there.
Kusagi
Joined Jul 9, 2021
I found that paramete in PSPICE MODEL
LowQCab
Joined Nov 6, 2012
5,101
The Program is asking for You to look at the Data-Sheet for
the CGS, CDG, and CDS values,
for the particular MOSFET that You would like to use as a Model in your new Circuit.
