Trying To Understand Current Flow
elec_eng_55
Joined May 13, 2018
214
Hi:
I am trying to understand the current flows in the following circuit that I ran in LT Spice.
I need to understand how you would determine the current split at both point A and point B if you did not have LT Spice
to do it for you. I keep coming up against conflicting information depending on the source. It makes my head hurt.
Thanks,
David
Jony130
Joined Feb 17, 2009
5,596
This circuit cannot be algebraically solved. We need to know the BJT's Is current.
For example if I assumed that the Is1 = Is2 = 1E-14A and β1 = β2 = ∞ and Vbe = 0.65V at 1mA.
We can find Ic2 this way
Ic1 ≈ (12V - 0.65V)/2.8kΩ = 4.05mA and solve for the new Vbe1 value
Vbe1 = Vt * ln(Ic1/Is1) = 26mV*(4.05mA/1E-14A) = 0.694V
So the new Ic1 current is
Ic1 ≈ (12V - 0.694V)/2.8kΩ = 4.04mA. Not a big difference so I stop the iteration process.
Now the Q2 current:
VR2 = Vbe1 - Vbe2 = Vt*ln(Ic1/Ic2)
Therefore
Ic2 = VR2/R2 = Vt/R2*ln(Ic1/Ic2)
Again we are forced to use the iteration techniques.
I start the iteration process by assuming that Ic2 = 3mA
Ic2 = Vt/R2*ln(Ic1/Ic2)
Ic2 = 26mV/10Ω*ln(4.04mA/3mA) = 0.774mA (1)
And the new value will be ( (3 + 0.774)/2 = 1.887mA )
2.6mA *ln(4.04mA/1.887mA) = 1.979mA (2)
(1.887 + 1.979)/2 = 1.933mA
2.6mA *ln(4.04mA/1.933mA) = 1.916mA (3)
(1.933 + 1.916)/2 = 1.924mA
2.6mA *ln(4.04mA/1.924mA) = 1.928mA (4)
(1.924 + 1.928)/2 = 1.926mA
2.6mA *ln(4.04mA/1.926mA) = 1.926mA (5)
So we are done the answer is Ic2 = 1.926mA
Of Course, we would include the β effect into the equation and solve it again by using iteration. And use the spreadsheet to do the iteration for us.
https://en.wikipedia.org/wiki/Widlar_current_source#Finding_the_current_with_given_resistor_values
But this calculations not include the Early effect.
But no one does this type of calculation when designing the audio amplifier mainly due to transistor mismatches (differences in Is current, β, Vce, temperature e.t.c), junction temperature has also a big effect. And normally we set the output stage bias current after we build the amplifier and wait until the temperature to stabilizes. We then correct the setting and wait again and so on.
elec_eng_55
Joined May 13, 2018
214
Hi:
Thanks,
David
Thanks Jony130
I guess this process works for small-signal only. If I look at a datasheet for say
the 2N3904, how would I determine the range in which this process would be
valid?
If I use current values much higher than Io = 2 mA and Iref =4 mA, then
the sim results don't agree with my calculations. I think people used to use an
IV curve but datasheets don't give them.
David
Jony130
Joined Feb 17, 2009
5,596
Something is not right with your spreadsheet. Because Io*Re = 10mA *2.23kΩ = 22.3V What ??
Let me check your calculations
Vbe1 = Vt * ln(Ic1/Is1) = 25.85mV *ln(25mA/1E-14A) ≈ 0.738V
R1 = (12V - 0.738V)/25mA ≈ 450Ω
and
RE = ( 25.85mV *ln(25mA/10mA))/10mA ≈ 2.3Ω
elec_eng_55
Joined May 13, 2018
214
and
elec_eng_55
Joined May 13, 2018
214
My spreadsheet did give me RE = 2.3Ω, I just entered the wrong value into the sim.
Even at that, the sim gives me Iref = 25 mA and Io = 11.83 mA, not 10 mA.
Is the objective here one of trying different values of Iref until you arrive at the
desired Io? And you just use whatever value of Iref is required in order to get
to that desired Io? Although my Iref = 4 mA and Io = 2 mA worked out without
doing the iterative process.
What is puzzling, is that I went into LT Spice left R1 = 450Ω but changed RE =
3.2Ω. Now Iref = 25mA and Io = 10mA as desired. But why would I have to
change Re from the calculated value of 2.3Ω to 3.2Ω?
Jony130
Joined Feb 17, 2009
5,596
Why I always have to remind you that the transistor is a highly nonlinear device.
And for our hand calculation, we are using a very simplified version of a transistor model ( the ideal transistor). And this model does not include a lot of "nonidealities" that LTspice includes.
For example, LTspice does the calculations for T = 27°C hence the VT ≈ 25.86492mV, the BJT's beta is not constant in LTspice but will vary with temperature, collector current, and Vce voltage.
Also, did you include the beta effect in your calculations?
If we want to do the calculations for the "Ideal" Transistor with this parameters Is = 1E-14; β = 100; and VT ≈ 25.86492mV (27°C)
And Io = 10 mA and Iref = 25 mA.
You should start like this:
IB2 = 10mA/100 = 100μA
Ie2 = IB2 + Ic2 = 10.1mA
Ic1 = (β1/β1 + 1) * (Iref - IB2) = 100/101*(25mA - 0.1mA) = 24.6534653mA
IB1 = Ic1/β1 = 246.534653μA
Vbe1 = 25.86492mV *ln(24.6534653mA/1E-14A) = 0.738012905V ≈ 738.013mV
R1 = (12V - 738.013mV)/25mA ≈ 450.4795Ω
VRE = 25.86492mV*ln(24.6534653mA/10mA) = 23.3387548mV
Re = 23.3387548mV/10.1mA ≈ 2.311Ω
Look at the simulation results for the ideal transistor
Any questions?
elec_eng_55
Joined May 13, 2018
214
Any questions?
Hi Jony:
One question about the calculation for Vbe1.
This result comes to 916.70 mV, not 738.04 mV. LTSpice says 738.013mV. Something
isn't right.
David
