For a project, I need to run some 12V components from a 13V battery. I have been searching for a switching voltage regulator that can be either bought or built which will regulate the voltage to 12V at 5A or more. High efficiency is vital as I don't want to avoid requiring heatsinks. I have been been searching for a long time and still don't have anything, although I admit that my limited experience with circuit design is likely a constraint.
Any suggestions to achieve this would be appreciated, but I also wouldn't mind some feedback on what I'm considering so far. The first is using a LTM4613EV. But the trouble I'm having with it is that none of the application examples included in the datasheet do not suit my needs. The closest example from the datasheet is this one which outputs 3.3V. I feel that there must be some way to adjust it to 12V instead but I don't know how.
The other option which I have just come across is to use a LT1083CP, which provides a much simple design:
The datasheet states a Vref value of 1.25, so I can easily find my resistor values according to the equation. My concern with this one is that it is linear, which I believe typically have a low efficiency and require the addition of heatsinks. The datasheet claims a high efficiency although I have trouble determining if it is comparable to a switching voltage regulator.
Any suggestions would be most greatly appreciated!
