MisterBill2
- Joined Jan 23, 2018
- 28,253
The complaints about using a PWM scheme to reduce the heat are all off base. A resistive heating system is an integrating system, and so reducing the power by switching it off during some time cycle that is much shorter than the thermal time constant of the heated portion will simply lead to a reduced temperature due to the reduced power input to the heater. The only reduction in efficiency would be due to the power consumed by the PWM circuit, which could be very small with a careful design.
Why do folks want to make things so complicated? A variable duty cycle PWM controller can be as simple as a dual 555 timer IC, with the first section serving as a ramp-wave generator and the second section serving as a comparator to drive an appropriately rated FET device to switch the heating power off and on. That is about as simple as it can be, also cheap and using easy to find parts.
