Trying to locate rotary switch
mike8668
Joined Aug 18, 2017
Picked up a dayton barrel fan that has a broken rotary 2-speed power switch. The manufacturer discontinued the replacement part so I'm sorta blowing in the wind. I've tried mouser.com and other sources but i keep finding links to home ceiling fan speed controls.
Below is the switch.
The fan assy is a Dayton/Grainger unit.
The switch is from Tower Manufacturing and is 120VAC 6A rated
MaxHeadRoom
Joined Jul 18, 2013
30,808
With just 3 conductors, a simple two position switch should do it, no?
If it is just switching the independent windings.
Is it enclosed somehow with those type of wire connection?.
Max.
MaxHeadRoom
Joined Jul 18, 2013
30,808
What are the positions low-high-off?
If so a simple 3 position switch such a Telemecanique ZB2B series, left -right maintained, centre off would do it.
Max.
