The display board/temp settings are in one unit and yes, are getting power from the boards. The ambient temperatures are displaying properly and I am able to change the setpoints individually.The display board must be getting power from somewhere.
Do the temperature displays appear to be show correct temperature?
Presumably, the display board (or controller) has to send control signals to the PSU in order to enable power to the fan and TEC. That is where you have to look at next.
I just fixed someone’s Miele dual zone wine cooler. The problem was user error in that the user did not know how to adjust the settings. Just saying.
I've finally had success in getting one of the boards, the upper zone, to work properly by replacing the C8 cap, and the lower zone to function semi-correctly. I'll explain below. But C8, it's always C8, what else, huh?
While trying to fix this, I was all along measuring voltages and checking components on BOTH boards, but had replaced C8 on one of them only (post #11 above), the lower zone specifically, and had reported that this didn't fix the problem.
I finally today replaced C8 on the other board (upper zone), and lo and behold, this one came to life right away. Once this started working, the lower zone came to life as well, albeit not quite as it should be. The problem I'm having with it is that it's not getting enough voltage to run the pelletier and fans. The bigger fan which cools the pelletier doesn't run as fast as it should, and there is a marked buzzing sound now that's coming from that board. I tested the fan itself on the working board, and it runs as it should, so we know it's not the fan. A transistor maybe? To further validate that and now that the upper zone is working, I re-measured voltage at the 7/12 pins of the 16-pin chips, and am getting 16volts at the upper zone (the one working properly) and only 11 volts at the lower zone (with the slow fan).
We're finally getting somewhere and need to now find out why the low voltage on the lower zone. What should I be checking next?
