Trying to fix a Marantz 2216 Part 1 of ?
thisandthat
Joined Mar 1, 2014
Picked this old project up again.
I'm out of practice working on electronics but did enjoy it in college.
Got a tone on the input, increased the volume until I got about a 1VAC on the main amplifier input.
Checked the DC voltages and they seem ok, however one channel is not amplifying. I'm thinking it is one of the main power transistors.
It has one 2SD313, and one 2SB507 on each channel doing the work.
I've got a little video on my measurements.
Video
I was hoping someone could give some suggestions if I'm on the right track, as well as how to find these old transistors.
MrSalts
Joined Apr 2, 2020
2,767
Video
You can try to find the originals or get some pin-compatible replacements with similar specs.
I would pull the Output transistors, and test of both using the diode range of a multimeter. A good habit is to measure the emitter resistors connected to the outputs. These resistors typically only fail with a shorted output, but it doesn't cost anything to measure them. FYI, I found the following transistor substitutes in a post on the Audiokarma web forum. This is a trustworthy source in my experience.
2SA564AC (H702) --> KSA992FTA
2SC1384 (H704) --> KSC2690AYS
2SC828 (H706) --> KSC1845FTA)
2SC1384 (H708) --> KSC2690AYS
2SA684 (H710 --> KSA1220AYS
2SD313 (H712) --> MJE15030G
2SD507 (H714) --> MJE15031G
