I would use the smallest gauge wire you have on hand. Wire-wrap wire is perfect.
I would solder one end of the wire to the signal source and just touch the other end to the lead going into the input capacitor shown in the schematic. Make sure you are connecting to the capacitor lead that is connected to the IC1 pin.
I can't see your setup. Are you able to access the area around IC1 with the power on? If not, then you will have to disconnect the AC power and solder both ends, one test at a time.
