Trying to find the amplitude at the gate of a mosfet
asdasd12e12
Joined Nov 24, 2021
48
When RLC is in a resonance state that means the total impedance seen by Vs is just Rs. I see no use in this information.
This problem kinda confuses me because there's no current flowing into the gate of this transistor so there would be no voltage drop in Rs so the amplitude at the gate would be the same of signal Vs.
Perhaps if the frequency wasnt the same as the resonance state there would be some flow because of the parasitic capacitance connecting to the source?
Edit, second attempt:
27,368
The current flows in as charge for the gate capacitance. Current is defined as charge flowing. The current flows in to charge the gate capacitance. Because that capacitance must charge before full conduction is achieved is why there is a frequency limit of FET transistor frequency response. And certainly charge must be delivered to charge that capacitance.
We learn that in the AC circuit analysis class, after completing the DC circuit analysis class.
DickCappels
Joined Aug 21, 2008
10,661
No, the gate has an impedance and current is flowing through it.
The LC looks like a short at resonance, leaving only Rs to limit the current.
What is the resonant frequency?
What is the voltage across Rs?
What is the current through Rs (and thus also through Lg and Vgs)?
What is the impedance of the Gate capacitance at that frequency?
With the known impedance of the gate and the known current, what is the voltage across Vgs?
asdasd12e12
Joined Nov 24, 2021
48
The resonant frequency is sqrt(1/Lg*Cgs) (rads/s) and the current through Rs (and Lg/Vgs) is Us/Rs.
The impedance of the Gate capacitance at that frequency is 1/(j * sqrt(1/L*C) *C) = Xc. With this info the voltage at the gate should be (Us/Rs) * Xc.
One thing that i'm not sure is that if the voltage drop in Rs is Us/Rs * Rs = Us then the voltage at the gate would be negative (still need to consider the voltage drop of Lg), but that doesnt go with the voltage drop of Cgs.
Jarvis1.1
Joined Oct 20, 2022
Olha, cuidado que quando fizeste Wo*Cgs, o teu Cgs é 0,75pF
DickCappels
Joined Aug 21, 2008
10,661
Note from moderator:
Translation is:
"Look, beware that when you made Wo*Cgs, your Cgs is 0.75pF"
This is an international website, it uses English as its only language. Please post in English only.
Este é um site internacional, usa o inglês como seu único idioma. Por favor, poste apenas em inglês.
27,368
Electrical resonance in the gate driver circuit is probably something to be avoided because it alters the impedance so much. And probably the exact capacitance is a production variable, with only a range specified in the data sheets.
DickCappels
Joined Aug 21, 2008
10,661
The voltage drop across Lg will be equal to the drop across Cgs because the impedances of both are equal. The voltage drop across Rs will be equal to Vs because the impedances of Ls and Cgs will cancel (the series connected impedances will equal a total of zero ohms, leaving only the resistance).
WBahn
Joined Mar 31, 2012
32,777
You've got it. Except you are getting sloppy with your math equations. The expression sqrt(1/Lg*Cgs) means sqrt((1/Lg)*Cgs) whereas you meant sqrt(1/(Lg*Cgs)). Those parens can't be left out. You really want to get in the habit of being precise about order of operations. Yes, most of us can read your mind and quickly figure out what you meant, but sooner or later you WILL get bit when you type an expression into a program or spreadsheet and unconsciously be expecting it to read your mind.
At resonance, there is still a voltage across the inductor and a voltage across the capacitor, but they are 180° out of phase and are equal in magnitude, so when you look across the combination of the two, you see no voltage, but if you look at each one individually, you can see significant voltage. In fact, you can see quite a bit more voltage across each than the supply voltage (consider the case if Rs << Xc).
WBahn
Joined Mar 31, 2012
32,777
Whether it is to be avoided or not is really not the issue for this problem, which seems to be exploring the question of what can happen with the parasitic trace capacitance IS in resonance with the gate capacitance.
