I think I do, your illustrations show 2 speakers but my car has 4. I have 8 wires. I thought you were just abridging your diagram, but maybe I didn't mention that in my first post.You don't need four of them.
The only thing I could see happening from from having more than one DPDT switch is that I could accidentally have speakers 1 2 and 3 on amp 1 and speaker 4 on amp 2. I would have the + and - terminals of one speaker on the same switch, so switch 1 is both terminals of speaker 1, and so on.The problem with having four switches is that you can switch them in the wrong order and end up shorting two outputs together.
Even having two DPDT switches you still run the risk of not switching things at the right time. Unless you plan on turning both amps off before you select which amp plays to the speakers.
And there's one more concern I have regarding the amp that is NOT connected to the speakers - isn't it hard on an amp when it has no load on it? This I don't know - I raise this question so that someone with more experience can answer it.
Shows my age. No ? ? ?Tony: Solid state amps are fine with the speakers disconnected. Tube or valve amps are not.
Yes. Sadly. And I agree, they ARE bullet proof.@Tonyr1084 Tony, Do you know how to use one of these:
The small town in Wisconsin I grew up in didn't convert to a dial system until I was in high school.Yeah, I grew up sticking my finger in the "Dial"
Siri? Or was it "Sarah"? Was on Andy Griffith.I guess we rather had Siri way back then.
by Jake Hertz
by Jake Hertz
by Jake Hertz
