Trying to figure out some preamp/amp compatibility issues
Audioguru again
Joined Oct 21, 2019
6,826
Your simulation shows fairly low distortion and a peak voltage of 20V into 8 ohms. It also shows 50W peak which is not a sinewave but instead is a short duration narrow pulse.
Then the output RMS voltage is 20V x 0.707= 14.14V and the output power is calculated as 25 continuous RMS W.
Audio is AC so the output power is RMS, never peak.
The datasheet shows the LM1875 is heating with about 20W, not 52W.
askDIY
Joined Oct 18, 2023
17
The amplifier power supply in this thread is not a single +24V VCC. Instead it is a single +50V VCC.
Yes sorry, that’s what I had it at earlier. With the 50V supply here is what the sim showed, 1710378535809.png
as you can see the amp puts out peak 25W and the load puts out peak 52W, which would cause the circuit to destroy itself
BobTPH
Joined Jun 5, 2013
11,627
No idea what you are trying to say here. Loads do not “put out” anything.
It’s like you are saying “I poured one liter of water into the bottle and then I took out 2 liters.”
I think you misunderstand what a speaker power rating means. If a speaker is rated at 25W, it means you can drive it with any amount of power up to 25W. Anything above that will cause severe distortion and eventually damage. But driving it with 10W is perfectly OK, it just will not be quite as loud.
BobTPH
Joined Jun 5, 2013
11,627
Most people play an electric guitar at a very high output producing severe distortion.
Not true. The distortion is created in the preamp, not in the output stage. You can play a low volume with a lot of distortion or at a high volume with no distortion.
Guitar amps have two level controls, the gain control (preamp) controls the distortion and the volume control controls the output level.
Audioguru again
Joined Oct 21, 2019
6,826
The rock music show is lighted by the clipping indicators on the power amps.
A squarewave from the preamp sounds as bad as severely clipping from the power amp.
askDIY
Joined Oct 18, 2023
17
Yes I meant the speaker. 52W would blow it, which is why I was looking for help on how to solve this
Audioguru again
Joined Oct 21, 2019
6,826
My Radio Shack Minimus 7 speakers each have a label: 40W MAX. I fed them each 15W or less RMS maximum of audio with no DC.
A few years later, one woofer burned out and it and the identical replacement were marked: 5W KOREA.
Your LM1875 amplifier feeds up to 25W continuously into your 25W speaker but occasionally feeds 50W peak momentary pulses.
It takes a fair amount of continuous loud playing (heating) to blow out a speaker.
An amplifier clipping badly all the time produces double its low distortion output power because half of its output power is producing distortion.
BobTPH
Joined Jun 5, 2013
11,627
If your 25W amp does not sound terribly distorted, it will not harm your 50W speaker. Stop worrying, and just don’t turn it up so loud it distorts.
LowQCab
Joined Nov 6, 2012
5,102
52-Watts RMS, ( basically meaning "Average" Power ), "may" burn-up your Speaker's Voice-Coil.
But it might take an hour at this RMS-Power-Level to actually smoke the Speaker.
Random-"peaks" of ~100-Watts will probably not do any damage, even in the long term.
The Quality of the Speaker, and the reputation of the manufacturer,
will determine whether or not You can actually believe the stated Power-Rating.
askDIY
Joined Oct 18, 2023
17
It’s a 25W speaker not a 50W, but either way, we will not be using at full volume so I should be good there. I did want to know a good way to dissipate heat on the amp chip itself? It’s extremely, extremely hot even when idle.
Audioguru again
Joined Oct 21, 2019
6,826
The datasheet for the LM1875 shows a typical idle current of only 70mA and with a 50V supply heats with only 3.5W.
Heatsinks are rated at a certain power at a safe temperature. Your IC heats to 20W when playing a 25W continuous RMS output.
Get and mount a 20W heatsink. The heatsink must not be enclosed.
