I'm working on a project that involves a Raspberry Pi case that contains a small circuit board. We need to reroute their board to our RPi header. The easiest way would be to use their onboard header with our own connector and wires. I have searched Amazon, talked to digi-key, etc... and cannot identify this connector. I think it's a JST connector. It's an 8-pin unit. The pin pitch appears to be 1.2 mm (which doesn't seem to be a standard, or current, JST - most are 1.0 mm or 1.25 mm). Overall connector width appears to be about 10.5 mm. Maybe it's not even a JST brand but a knock-off or another company.
Ideally, I need the connector with wires attached (about 8" so we can connect dupont connectors on the other end).
Can anybody help?
Thanks!
Can anybody help?
Thanks!
